Power Steering Pump, how hard? '95 Windstar
Old Apr 1, 2008 | 11:34 AM
warpwr's Avatar
Default Power Steering Pump, how hard? '95 Windstar
What's involved in replacing the power steering pump on a '95 V6 3.8L?
It doesn't look too hard and mine has been making growlingnoises for long enough.
Any advice is appreciated, thanks.
Vaughn
Old Apr 1, 2008 | 02:29 PM
Default RE: Power Steering Pump, how hard? '95 Windstar
The power steering pump replacement requires a puller/installerto remove the pressed on belt pulley.. There's a few variations in type, like a 'split collar' or a open end type puller.. The groove up on the nose of the pulley has to be snagged with a good portion (to all) of the puller tool so not to damage the pulley, then needs to be pressed/installed back on the new pump.. The new aftermarket pumps may come with a bolt style installer (install only) but will do the job.. The worst part of the job is to remove the belt pulley in tight quarters..Here's a few pics of the different designs.. You may be able to rent a puller set from your local rental store, or their available from most parts vendors.. I can send you the replacement steps if needed..
[IMG]local://upfiles/6756/E16A87A79949403BB93DD37BF00EC1B2.gif[/IMG]
[IMG]local://upfiles/6756/36B70A1D7A134C5F881C2B5A4CE40DE3.jpg[/IMG]
jozepy24
Jul 13, 2019 05:21 AM
ryche
Feb 27, 2015 01:35 AM
strider380
May 20, 2006 11:10 PM
bsmith
Apr 27, 2006 12:28 AM
bsmith
Dec 25, 2005 10:37 PM
