Aspire/Festiva/Fiesta Possibly one of the original "sub compacts" this car offered amazinf fuel economy.
Fiesta MK4 STILL doing my head in..
Old May 18, 2013 | 03:18 PM
mattcreate's Avatar
Default Fiesta MK4 STILL doing my head in..
Yes, believe it or not my Fiesta MK4 1.3 i is still not running. To recap, car starts ok,revs die down after a few seconds,runs rough,smells gassy,drinks fuel,if driven will cut out and refuse to restart. First diagnosis( mechanicīs hand-held diagnostic computer) was "throttle position sensor",new one fitted,no change.Since then; MAP sensor,air idle valve,fuel pressure regulator,lambda sensor,engine temp.sensor,injection wiring loom,injectors&distributor pack( tested )ht leads,plugs and the ECU(replaced). Car is still the same,any new ideas?
Old May 21, 2013 | 04:13 PM
go-part's Avatar
Former Sponsor
Has your mechanic done a compression test?
Sounds like your engine is running rich
Old May 22, 2013 | 11:33 AM
bluewind's Avatar
Did you test the fuel pressure?
Did you check the fuel pressure regulator? If the membrane is broken extra fuel goes into the intake manifold and could flood your engine. Take off the vacuum line and see if it smells like fuel.
bignick71
Mar 2, 2014 08:17 AM
trev0006
Jun 5, 2013 11:50 AM
mattcreate
Dec 19, 2012 08:56 AM
daveranger
Oct 21, 2006 03:27 PM
JMH
Jun 8, 2005 02:25 PM
