Ranchero -72 steering gear
Old 07-27-2007, 04:34 AM
Fordvessa's Avatar
Default Ranchero -72 steering gear
I want chance my power steering gear to manual steering gear, is it possible and what I need to know?
Where I can buy manual steering gear?
Old 09-06-2007, 06:37 PM
goinstrong's Avatar
Default RE: Ranchero -72 steering gear
It is only really possible if Rancheros of your general year had the manual gear boxes. Then you would have to find one in a salvage yard and be sure it bolts on the same and has nearly the same angles on the linkages. Then you would have to check exact center to center of the bolt holes when you unbolt the gearbox. Last you have to check the tilt of the steering column to see if they match (often they're off a bit). If they're close enough you can probably work with it - just make sure to get as much of the steering parts from the donor car as possible.(gearbox, column, arms, links andspindles).
Old 12-11-2007, 10:13 AM
Your 72 Ranchero is the same as any Ford big car of the era. So Galaxies, wagons, etc. are all the same. What I'm curious is why would you want manual steering in a 4000 lb car? You'd have fore arms like Popeye after driving that!
BaaRamEwe
01-29-2020 08:10 PM
Yapalot
04-26-2011 05:29 PM
projectprerunner
12-27-2007 04:06 PM
buffalojump
02-11-2007 07:07 PM
moomimoom
01-09-2006 08:22 AM
Quick Reply: Ranchero -72 steering gear
