starting issues
Old 05-24-2016, 03:54 PM
koolmanjohn's Avatar
Angry starting issues
I have a 1966 ford galaxie with a 1970 390engine. trying to get it started for the first time after rebuild.
the engine will fire but cuts out . what am I just not seeing. ive got a wiring diagram and have checked and double checked the wiring
any help would be appreciated
Old 05-24-2016, 11:21 PM
Thumbs up
Welcome to the site..
How long is the 'run time' before it stalls out?
After it stalls, does the carb accelerator pump still squirt fuel into the intake?
Seem to be flooded on restart?
Seem to run on all 8 before it cuts out? (Firing order?)
Spark drop out?
Timing, gap/dwell is spec?
All vacuum connection/leak points checked?
Old 07-23-2016, 11:42 PM
Sanddoc's Avatar
My 2 cents
1. does the car start?
2. How long does it run before dying
3. is it at idle or are you giving it gas?
4. is it a rough idle or smooth?
If it runs we know you have spark.
Like above, check for vacuum leaks, around base of carburetor, vacuum hoses
if you have not changed any of those do so
when did you change the fuel filter and fuel pump..
dwarber
11-04-2009 12:12 PM
cdawson815
12-20-2006 01:55 AM
grnded
12-01-2006 05:40 PM
Allnbrgdn
10-11-2006 02:21 PM
Grabauaz
05-18-2006 09:23 PM
Quick Reply: starting issues
