2001 E150 rear brake line left side fitting size?
Old 10-23-2016, 08:34 PM
hdvespa's Avatar
Default 2001 E150 rear brake line left side fitting size?
Rear line between junction and left wheel cylinder. What size fitting goes into the junction. I know it's not 3/8-24 double flare.
Old 10-24-2016, 01:42 PM
There is a very good chance it is Metric and your nearby auto supply store probably has a section of that size already made. If you can take the old line and have them see it and they should be able to come up with a close correct replacement.
Old 10-24-2016, 09:08 PM
hdvespa's Avatar
Hanky. I know the side going into the wheel cylinder is 3/8-24 and side going into junction is not. Most auto stores dont have mixed size fitting on lines that are 20 inch long
QUOTE=hanky;99640]There is a very good chance it is Metric and your nearby auto supply store probably has a section of that size already made. If you can take the old line and have them see it and they should be able to come up with a close correct replacement.[/QUOTE]
Old 10-25-2016, 02:27 PM
I would first confirm the proper size nut to fit the fitting then get a line with that size nuts, remove the cyl end and install the proper nut there and make the correct flare.
Polly
07-20-2016 04:16 PM
ba_50
02-26-2016 02:57 PM
eric hoffmeyer
10-20-2013 10:43 AM
gwald
03-26-2006 01:09 AM
Socal4521
08-02-2005 03:41 PM
Quick Reply: 2001 E150 rear brake line left side fitting size?
