1995 explorer 4.0...engine problems
Old 08-29-2011, 11:57 AM
rgreenwade's Avatar
Default 1995 explorer 4.0...engine problems
i have a 1995 explorer...recently purchased off of a friend and was running very good but i always replace wires and plugs when i purchase a new vehicle. once i put them in it started missing very bad. i took the plugs out and noticed #5 cylinder plug was charred black...what does this mean? clogged injector?
Old 08-29-2011, 02:01 PM
I would you recheck your work. Could you have pulled on one of the plug wires and opened the connection? Did you check the plug gap before installation?
Usually the black is caused by an excessive rich condition or plug not firing.
You might try swapping the plug with another cylinder and see if the miss goes with the plug. Let us know what you find.
Becca Moore
12-22-2012 05:01 PM
rob1992
12-01-2012 11:44 AM
gnorton52
10-03-2010 07:57 PM
kage_unknown
08-21-2008 01:38 PM
harryo007
08-08-2005 11:49 PM
Quick Reply: 1995 explorer 4.0...engine problems
