lower ball joints on a 2000 explorer
Old 07-31-2008, 09:15 PM
homegrownrmk's Avatar
Default lower ball joints on a 2000 explorer
Found out I need to change out the lower ball joints on the A-arms of my 00 explorer4x4. I'm told they need to be pressed out of the arms. How hard are they pressed in there? Can I just rig up one of my pullers to get them out, maybe with some heat? I really don't want to pay an estimated 5hrs shop time for someone to do it for me.
Old 08-01-2008, 12:21 AM
Default RE: lower ball joints on a 2000 explorer
Harbor Freight has a press setup that is about $50. You can also get a loaner at Autozone. There is a snap ring on the top side of the lower A arm that needs to be removed before you pull the ball joints. You can press them in with the same tool you took them out with or a floor jack. Probably best to soak them overnight with PB Blaster or Kroil before starting.
Old 08-01-2008, 06:11 PM
ahh forgot about harbor freight, the best place to go for cheap tools that will probably only be used once. Thanks J.A.F.E.
fitter1974
01-31-2009 10:23 AM
cchev
04-07-2008 06:50 PM
alicianc
01-08-2006 12:00 AM
ab1844
10-13-2005 11:38 PM
harleybadboy2
06-03-2005 09:51 PM
Quick Reply: lower ball joints on a 2000 explorer
