upper & lower ball joints???
Old Jan 7, 2006 | 04:34 PM
alicianc's Avatar
Default upper & lower ball joints???
H
Hello. I have a 97 Ford F-150. Yesterday as I backed out of my yard I heard a big thud noise come from under the truck as I was turning my steering wheel backing out. I continued driving and 5 minutes later the thud noise continued several times. Finally each tie the noise occurred the steering wheel would slightly jerk and a scrubbing noise was hear. Each thud lasted about 2 or 3 seconds. When I returned home I drove 30 mph with my blinkers on and the noise happened once. This morning I drove it to a mechanics's shop and I drove the regular speed and no noise happened and no wheel jerking. 3 hours later the mechanic called and said they needed to replace the upper and lower ball joints. With labor and parts it would be around 800 dollars. Is this the normal price range? Is this typical "symptoms" of ball joint problems? I'm waiting to hear from anyone. Thanks![:@]
Old Jan 8, 2006 | 12:00 AM
WWEBS's Avatar
Default RE: upper & lower ball joints???
THIS IS PRETTY NORMAL ON THIS TRUCK BUT YOU DIDNT SAY HOW NANY MILES ON IT AND YES IT IS COSTLYALSO MAKE SURE TO HAVE THE PITARM CHECKED ON THE STEERING BOX THEY ALWAYS GOE BAD AND WILL GIVE A CLUNK OR SQUEEK NOISE HOPE THIS HELPS
joshhemming
Sep 6, 2011 02:53 PM
homegrownrmk
Aug 1, 2008 06:11 PM
cchev
Apr 7, 2008 06:50 PM
e250extended
Dec 24, 2007 12:32 PM
harleybadboy2
Jun 3, 2005 09:51 PM
