Pulling oil pan on a 1997 F150 4.6
If you have a rod bearing spinning, or any galling/damage to the journal surface from the hammering rod, chances of polishing the crank journal and just slipping a new bearing in would be pretty lucky.. Usually the failing bearing will let debris travel into the other bearings in the low end as well..
