1975 f350 wont start
Old Jun 11, 2013 | 02:16 PM
Cordell Scott Nicholson's Avatar
Exclamation 1975 f350 wont start
i have a 1975 f350 with a 390 in it and it will not even turn over. i turn the key and nothing happens, battery is good and charged, changed the solenoid and it is still not working. I need any help fast. please anyone put your two cents in!
Old Jun 11, 2013 | 02:26 PM
Is it std or automatic?
If automatic , check the neutral safety switch, if std check the clutch safety switch.
Old Jun 11, 2013 | 03:13 PM
were would it be located on a manual
Old Jun 11, 2013 | 08:45 PM
Usually located on the clutch linkage between the pedal and the clutch fork. Look for a switch on the rod that moves when you step on the clutch pedal.
Old Jun 11, 2013 | 10:57 PM
thanks i'll take a look in the morning
Old Jun 28, 2013 | 07:20 PM
grindman's Avatar
it's just to the left of your brake light switch mounted the same way.
Old Jul 9, 2013 | 02:01 PM
uribeflores1's Avatar
it can also be your neg battery terminal not grounded properly my 1976 ford f250 had the same problem i just linked it straight to one of the bolts holding the starter
Jun 11, 2013 05:14 PM
amiehuffines
Sep 6, 2012 07:19 PM
Saskatchewan F-350 SuperDuty Lariat
Dec 20, 2010 08:54 PM
DShaw
Mar 23, 2010 08:59 AM
tnjwilborn
Dec 18, 2007 01:30 PM
