V-10 or Diesel
Old 05-08-2009, 07:08 PM
phboy0214's Avatar
Default V-10 or Diesel
Hey everyone,
I am looking at purchasing an F 250 or F 350 (4x4) in the next few months. The reason for this is my family is looking at a 30' to 35' 5th Wheel Trailer. The trailer will be parked most of the time, but i want a truck that can pull the trailer when necessary. Which engine would you recommend, the V-10 or the Diesel. ( i will most likely be buying a used truck if that makes a difference) Thanks for your Help
Old 05-08-2009, 07:55 PM
eightrac's Avatar
Either will do the job fine. If you get a V10 ensure you buy one that has 4.30 or numerically higher gears.
Ford diesels have a track record for being so-so (since the 6.0L). I wouldn't advise getting a 6.4L due to it not getting much better mileage than the V10 and a 6.0L is just a mistake anyway.
Old 05-09-2009, 05:14 PM
phboy0214's Avatar
Thanks eightrac i appreciate the response. Would a 4.10 gear ratio but much different than the 4.30. Those are the two options when building a truck on Fords website. And have you heard anything about the longevity of the V-10 engine? Any major mechanical problems that i should be worried about. I most likely will only put between 8,000 and 10,000 miles a year on my truck when i have it if that helps.....
Old 05-14-2009, 07:20 PM
eightrac's Avatar
Your only gripe will be fuel mileage. The engine is bulletproof and will most likely never fail you as long as you take care of it.
If you are looking for fuel mileage, find a 7.3L truck.
windystar
08-27-2019 01:44 PM
wannarace777
12-07-2005 03:44 PM
harleybadboy2
08-16-2005 05:22 PM
garworth
12-30-2004 09:25 AM
doctor
12-16-2004 08:17 AM
Quick Reply: V-10 or Diesel
