ATF in the fuel to clean injectors?
Old 08-27-2010, 05:05 PM
Kurt W's Avatar
Default ATF in the fuel to clean injectors?
I was told you can put Automatic Transmission Fluid in the fuel tank and it will help clean out the diesel injectors, Will this work on a 2004 6.0?
Old 02-16-2012, 01:32 PM
indigoshaman's Avatar
Default adding transmission to fuel
it would be better for the engine if you use "marvel mystery oil", a product made for diesels used since 1890's
can use trans fluid on carburated vehicles no harm but would not reccommend trans fluid on diesels....seals are different on diesel engines and injectors...
chemoman
09-06-2016 10:47 PM
Wmtitan024
02-26-2012 02:12 PM
jwplunkett
01-14-2008 10:57 PM
dsljay
03-25-2007 01:01 AM
Quick Reply: ATF in the fuel to clean injectors?
