trouble need help
trouble need help
I have a 06 f 250 with a 5.4 L with 204147 km and are starting holidays this week and my check engine light just came on so I borrowed a code reader and this is the code p0352 ignition coil b primary/secondary, any help would be awesome.
Look for a problem with the 2nd cyl back from front on pass side . Could be spark plug, coil, boot, plug to coil even PCM.
If you haven't had any coils changed yet , may be due.
Shouldn't wait too long because if a coil is shorted it could wipe out the PCM. And that is expensive.
I bought this truck had 160,000 k , I haven't changed any plugs on it on done regular maintenance since I have owned it has always ran good. I will change the plugs and check all the connection on the coil packs I will move the coil that is mentioned is there any cylinder I should move it to. Thanks for all the help.
I let them soak over night with carb cleaner and worked back and forth loosening and tightening and I ended up breaking 4 . So I will be removing them today. I will be the coil pack you have mentioned to the drivers front cylinder and hopefully this will fix my problem. Thanks for all the help.
