Turn signals don't work
Old 09-16-2010, 12:39 PM
1bigfordlover2's Avatar
Default Turn signals don't work
My turn signals don't work any more. I replaced the bulbs, flashers, dimmer switch, signal switch on the column and the fuses. The emergency flashers work just fine. Can anybody help me out? It is a 1984 F-250, 351 W, 4-speed.
Thanks Mark
Old 09-16-2010, 02:27 PM
As soon as I can check this out I will try to get an answer for you.
In the meantime, this is what I have to check, Does your truck use two separate flashers ? One for the hazards and one for the signal lites. If it has two then all you need to do is find it. Will get back to you. ,,,,,,,,,,,,hanky
Old 09-16-2010, 04:35 PM
It does have two flashers and i replaced both of them with heavy duty flashers.
Old 09-16-2010, 05:27 PM
Do you still have the problem of ---no signal lites?
Old 09-17-2010, 04:42 AM
If I remember correctly, in order to replace the signal lite switch assy how did you get the plug thru the column without removing all the wires from the plug?
Next At that plug do you have juice to the switch from the flasher?
OraDBAforPsoft
10-16-2013 06:37 PM
Durr
10-08-2011 09:02 PM
CADOP
01-01-2011 05:58 PM
ChuluotaBlackie
12-22-2008 06:09 PM
Luke 22
01-27-2007 03:26 AM
Quick Reply: Turn signals don't work
