Vacuum Pump
Vacuum Pump
1999 F 350 7.3 Diesel, 6 speed 2 WD.
The selector switch that directs cabin air to the window, face feet etc no longer works.
It suddenly stopped one day.
I am guessing that the vacuum pump is gone.
Here is what I did to check it. Let me know please if I have missed anything.
1. All fuses are good.
2. Connector at the pump is clean, tight and no frayed wires.
I disconnected the pump wiring harness connector, put he ignition to run and then plugged the connector back in. I was expecting to hear the pump run and to sense some vacuum from the hose leading out of the pump.
I got nothing.
Is it new pump time?
Regards,
Eric
I got nothing.
Regards,
Eric
I am not sure if you have purchased a pump yet but if you have not I would suggest OEM. There are a two different part numbers available depending on vehicle options. If the pump is belt driven you will need part number F6TZ-2A451-AA (#F6TZ2A451AA: Vacuum Pump) and if it is an electric drive pump you will need part number 6C3Z-2A451-A (#6C3Z2A451A: Vacuum Pump).
jozepy24
07-13-2019 05:21 AM
fordexpedition2006
04-21-2017 05:23 PM
jbrote47
01-27-2006 12:52 AM
