no spark
Old 01-26-2014, 06:39 PM
mikeatpriestlake's Avatar
Unhappy no spark
hi, have an 86 ford ranger, 2.3 4cyl. got no spark, no powr to the fuel pump, which works fine, we bypassed to test it. the ICM tests ok and so does the coil. We also bypassed the inertia switch, still no spark, no power to fuel pump. have dash lights and she turns over fine. died while driving. timing belt ok, and so is the distributor gear. All of that wouldn't keep power from the fuel pump tho. Any help would be appreciated, thanks.
Old 01-27-2014, 03:26 AM
Do you have power going to the coil from the ignition switch with the key on?
Old 02-01-2014, 07:08 PM
Question new developement
86 ranger, couldn't get spark or fuel. tested coil, icm, put in new ignition switch. fuel pump works, cleaned ground on block. nothing works. engine turns over. I took out the computer to go to pull n save and couldn't find one. Just for giggles, I tried for spark with no computer installed. It worked, lots of spark. still no power going to the fuel pump, but got spark. "So does this mean the computer is bad? also replaced fuel pump relay. I am thinking It has to be the EEC. any other ideas would help, thank you.
Billy62
03-31-2014 05:08 PM
JCtrayer
11-22-2011 10:07 AM
JCtrayer
10-28-2011 05:32 PM
Rogerseric
08-12-2011 12:34 PM
67comet
01-01-2007 02:47 AM
Quick Reply: no spark
