1999 taurus 3.0 no heat
Old Nov 18, 2007 | 02:30 AM
jshort's Avatar
Default 1999 taurus 3.0 no heat
hear is my story hopefully someone can help.my wife's 99 ford taurus wagon would not blow heatthis fall.a local mechanic and i noticed the coolant was terrible looking so we drained it and removed the heater hose ,made a fitting and backed flusshed the heater core untill clean water came out.we refilled it with water only and had to spend a lot af time getting the air out but were sucsessfull and everything worked fine.good heat the problem started a few days laterwhen i drained the water and filled the system with coolant.it will only produce proper heat at high rpm only cold air at idle.can anyone help
wife very unhappy wearing carharts and longjohns to drive
Old Nov 21, 2007 | 10:22 PM
karehandler's Avatar
Default RE: 1999 taurus 3.0 no heat
I had the same problem, impeller blades insidemy water pump was rusted out so badit was causingthe coolant not to flow...Your problem could be something else, but that my 2 cents...
Use Common Sense
Jun 25, 2016 01:30 PM
1999EBEXP
Oct 24, 2011 10:58 AM
escortjtc
Jan 17, 2009 03:23 PM
tyler513
Feb 11, 2008 01:55 PM
