Gas Pedal Sticking 2005 Taurus
Old Apr 11, 2013 | 07:24 PM
  #11
Grounger's Avatar
My '05 Taurus has been plagued with a sticky gas pedal for close to a year. Sometimes a couple times a week, sometimes a few times a day. I've been able to experiment a few times when it happened on the open road with no traffic and found that if I hit the cruise control "On" and "Set" buttons simultaneously and then press "Coast", the gas pedal will come up with an audible "pop". The funny thing is that cruise control doesn't work and hasn't for over a year. I have read in some forums that a faulty cruise control cable can be the culprit. I'm inclined to agree. Does anyone know if it's a complicated fix?
Old Apr 12, 2013 | 05:27 PM
  #12
JackC's Avatar
Did you try the suggestions given in the first few posts of this thread?
If not give them a try because I have heard others having good luck with those approaches.
Old Apr 13, 2013 | 02:18 PM
  #13
Grounger's Avatar
Well, for anybody still interested in this thread, I finally decide to fix the problem and it turned out easier than I had expected. After reading many different forums that discussed similar problems I looked at the throttle body and sure enough, there was the end of the cruise cable, disconnected. I reattached it, taped it to help keep it from popping off again, and now, after a year and a half, my cruise control works.
Time will tell if I've fixed the stuck gas pedal problem, but it's easy to see how the pin on the throttle mechanism could have gotten snagged on the end of the loose cable.
Old May 20, 2013 | 02:44 PM
  #14
Jodie's Avatar
Thumbs down Sticky throttle on 2005 taurus
My 2005 taurus clocked @ 75 mph before i could get the car back to 0 again .. It scared my children and myself to death .. I put it in N then gave a swift push to pedal and it clicked .. But what happens when it doesn't click ..
Old May 21, 2013 | 09:39 PM
  #15
Grounger's Avatar
Jodie,
Does your cruise control work normally?
Old May 22, 2013 | 11:39 AM
  #16
bluewind's Avatar
Old May 22, 2013 | 11:54 AM
  #17
Grounger's Avatar
I filed a complaint last year with the NHTSA when I heard they were investigating the issue. Heard later that they were taking no action because problem wasn't widespread, which is hard to believe! Like I said in an earlier post, mine was a simple fix. Reataching and securing the cruise cable gave me back my cruise control and fixed my runaway throttle problem.
Old Jul 5, 2013 | 09:50 AM
  #18
Jodie's Avatar
Default @ grounger
Originally Posted by Grounger
Jodie,
yes it still works properly ..
detguy
Apr 1, 2014 10:16 PM
tfgrnwd
Feb 15, 2013 12:52 AM
Schoolteacher
Feb 12, 2013 12:42 AM
roses15534
May 5, 2011 08:34 PM
roses15534
Jan 9, 2008 11:38 AM
