96, V6, T Bird fuel pump
Old 04-26-2009, 09:15 PM
cjspanksj's Avatar
Default 96, V6, T Bird fuel pump
My 96, V6, T bird was running fine until one day it started sputtering. I was intermintant all day and now wont start at all. There is a schrader valve on the fuel line at the intake manifold. I press it and there is maybe 5 psi of fuel coming out. Can anyone tell me how many psi there should be ??? Also checked spark with a screwdriver between the boot and distributor cap and had a good arc. HELP !!!
Old 05-18-2009, 07:18 PM
Robtbird's Avatar
Default fuel pressure
You should have 20 to 40 psi to run the injectors, Where are you from, I have one I pulled from a 96 with a v6 in it. Thanks, Rob
jozepy24
07-13-2019 05:21 AM
fordexpedition2006
04-21-2017 05:23 PM
Spaznaut
05-24-2014 02:10 PM
ballaholic29414
11-12-2010 06:04 PM
grumpydave
01-18-2008 03:15 PM
Quick Reply: 96, V6, T Bird fuel pump
