2001 Taurus gas gauge
Old Jan 11, 2012 | 02:31 PM
hfb1957's Avatar
message deleted and reposted today
Old Jan 25, 2012 | 03:05 PM
hfb1957's Avatar
Default 2001 Taurus fuel gauge
I have a 2001 Taurus that runs fine most of the time, but lately the fuel gauge has been dropping to empty and the car starts to stall out. Even with a full tank this still happens. After a few minutes the gauge will return to normal and the car runs fine again. It is doing this more and more so I really need to figure it out. Any idea on what to check first will be greatly appreciated.
Thanks
Henry
1987 F-250
2001 Taurus
2005 Focus
2007 Taurus
Old Jan 25, 2012 | 04:41 PM
bluewind's Avatar
I suspect it is the Fuel Sending Switch. Judging from pictures it has a float that will drop with the fuel level and thus operate a switch that delivers a voltage related to the float's position.
Before taking it out I would try a fuel system cleaner---just to try my luck.
check this article as well:
http://autorepair.about.com/library/faqs/bl845g.htm
Old Jan 26, 2012 | 02:03 PM
hfb1957's Avatar
Okay I will check it out but does the sending unit only control the gauge or would it make the car run rough even with a full tank.
Old Jan 26, 2012 | 02:19 PM
I could be wrong here, but I would suspect a questionable ground connection at the fuel tank module (sending unit & pump) . Since if it were either one, gauge or pump voltage supply , only that one function would be affected. Since both usually share a common ground I would start there.
Old Jan 27, 2012 | 10:35 AM
hfb1957's Avatar
Thanks I will check it out and get back.
oldad
Aug 2, 2012 08:11 PM
blake
Aug 8, 2006 12:43 PM
jp_waltz
Apr 24, 2006 04:59 PM
brad14880
Apr 7, 2006 03:12 PM
