Aspire/Festiva/Fiesta Possibly one of the original "sub compacts" this car offered amazinf fuel economy.
Fuel Rail Pressure graph interpretation please
Old Oct 28, 2018 | 08:58 AM
Mariusz Skonieczny's Avatar
Default Fuel Rail Pressure graph interpretation please
Hi all
I have got a Fiesta 1.6TDCI 2009 with small cutting off issue. The car shuts down while passing 1000rpm on acceleration, completely randomly.
Already replaced fuel filter, air filter, checked for boost pipe leaks etc all the usuall stuff. Injectors removed and tested at Bosh injector center, all fine.
Could anyone with appropriate knowledge interpret the below graph for me please? It is a FORScan read of actual fuel rail pressure - FRP red line, and desired fuel rail pressure - FRPD green line.
Two worries here - it takes a lot time to stabilise the actual after firing the engine up, at warm engine. Secondly there are two spikes going opposite ways - desired up, actual down. This is the very moment engine stalls.
Mine uneducated guess is high pressure fuel pump going to die?
All help much welcome and thanked for.
Old Oct 29, 2018 | 03:14 AM
It might be a good idea to see why the pump is losing power. It may not be the pump itself.
Where are you plugged in to get the reading? Pump directly,, inertia sw ,, fuse ?
Tinbender
Oct 24, 2018 09:14 AM
raymo46
Apr 29, 2012 07:33 PM
30ford
Aug 22, 2011 08:40 AM
pilleway
Jul 9, 2011 10:50 AM
digby
Mar 19, 2009 04:08 PM
