Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
transfer case problems
Old 08-31-2011, 04:58 PM
fordmandan29's Avatar
Default transfer case problems
hi, I own a 1988 bronco ll 2.9L 4x4 and I'm having some trouble with the transfercase. when I put it in four wheel it doesn't click in, like most that I have driven, and the lever will kick out of four wheel drive with the brush of a finger, even going on a downhill grade it will kick back out into 2 wheel drive. also I had the rear driveshaft out a while ago and it went just fine with just the front wheels for the two days that I was driving it like that, minus having to bungy cord the transfer case shift lever back so it would stay in four wheel going down a hill, but once I put the new driveshaft in and tried the four wheel it acted like it wanted to grind to a stop and didn't seem to be moving as smoothly as it should. I have asked around and heard everything from not being all the way into gear when I put in in to the transfer case being shot. the 4x4 light on the dash comes on but the low range light lights up a little bit as well. any information on what the problem could be would be greatly appreciated. thank you
Old 08-31-2011, 06:54 PM
I would suspect a possible problem with the shifter fork in the transfer case. It could also be a problem with the detent system that keeps the rail in the selected position.
Old 09-01-2011, 04:35 PM
o.k. thank you, I will check that out first chance I get.
85_ranger
09-30-2012 11:19 PM
caryrae
03-20-2006 09:12 PM
jray
01-16-2006 04:50 PM
aintsaword
11-17-2005 12:51 PM
Tempestv
06-09-2005 02:00 AM
Quick Reply: transfer case problems
