Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
89 Bronco will not start w/ the key
Old Dec 16, 2010 | 12:00 PM
withthewind's Avatar
Default 89 Bronco will not start w/ the key
I have an 89 Bronco that will not start with the key. I have replaced the ignition switch. The only way I can get it started and running is by shorting the two large terminals on the relay (passenger side wheel well). I have also replaced the relay as well. Anybody have any ideas what the problem might be?
Old Dec 16, 2010 | 01:59 PM
Try running another ground wire to the base of the solenoid. The sheet metal the solenoid is bolted to has probably corroded and is not making a good connection for the solenoid to operate.This would be a good time to check all the ground wires you can see, clean them and place some grease or even vasoline over them to reduce exposure to the air and moisture. Usually works!
Old Dec 16, 2010 | 08:55 PM
Bullitt94's Avatar
+1
If you can jump the solenoid it is either a bad wire/ground or bad solenoid.
Hambrock10
Jul 10, 2013 05:11 PM
NYCArmyWife
Nov 16, 2008 12:29 PM
Pastor Wells
Jul 11, 2007 08:46 AM
Pastor Wells
Jun 30, 2007 08:21 PM
