Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
hot 96 contour
Old Feb 14, 2013 | 09:55 PM
WSW's Avatar
WSW
Default hot 96 contour
I have a 96 Contour that just started tunning hot,I,ve replaced waterpump,timing belt,drive belt,thermostat,temp sensor,cooling work good, flushed cooling 3 times,has interminnet heat,starts fine,smooth idle,the upper hose gets really hard and coolant tank is really hot ,alot of pressure on hose and tank,it seems that when the thermostat opens the motor lays down alittle and can see very very little steam from the tail pipe,don,t know what else to check,please help any replys would be greatly excepted
Old Feb 15, 2013 | 01:55 PM
bluewind's Avatar
Check compression and consider a cylinder leak down test. This is to find out whether the head gasket is bad.
Old Sep 20, 2013 | 03:42 PM
CharlesC's Avatar
Smile Hot engine
Too bad I did not see this before. I have a 96 GL Contour which is a winner for us with only 68K on it. Has the V-6 strong engine also.
I had same problem. Ford used plastic vanes on the water pump, they fall off and no circulation to speak of. Get new water pump.
Old Sep 21, 2013 | 04:42 PM
bluewind's Avatar
Yes, but the guy replaced the water pump and still had a overheating problem.
Old Sep 22, 2013 | 07:21 AM
WSW's Avatar
WSW
I did a Compression check 180,125,130,185,i think it might be blowing between # 2 and #3 cylinder and see bubbles in the coolant tank.
Old Sep 23, 2013 | 11:28 AM
bluewind's Avatar
Yes, indeed!
SAMF
Apr 30, 2010 12:07 PM
95se_mexican
Dec 16, 2006 06:52 PM
mbutz13
Aug 26, 2005 02:02 AM
zacfrd
Jul 12, 2005 12:03 AM
josser
Jun 21, 2005 07:28 PM
