Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
Power lock issues on 1998 Ford Contour
Old Oct 9, 2011 | 06:23 AM
lola97882@gmail.com's Avatar
Thumbs up Power lock issues on 1998 Ford Contour
The power lock on the drivers side door is stuck. The door will NOT open! I have tried manually unlocking, using the door handle to open, tried using the key on the outside to open it but NOTHING has worked! Help! I'm having to crawl in through the passenger door and it is a pain in the ***! Anyone else had that problem???:co nfused:
Old Oct 11, 2011 | 04:20 PM
bluewind's Avatar
You may be able to pry out the switch replace it and see if a new switch works.
If that doesn't work have it slim-jimmed by a shop or locksmith. Then take the door panel off so you can see the mechanical parts inside and fix them.
And don't crawl through the passenger door, that looks funny, just sit in and slide over.
BigChevy80
Feb 11, 2012 05:09 PM
pokey2001ca
Jul 23, 2009 10:36 PM
barral2
Jan 6, 2009 10:29 PM
wmlperry72
May 17, 2008 08:30 PM
Mobile AV
Aug 17, 2005 04:01 PM
