Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
Rough Idle
Old Sep 15, 2012 | 01:46 PM
  #31
97Contour's Avatar
ill check out the vct, cleaned the maf but didnt disconnect it,ill try that also,thanks
Old Sep 15, 2012 | 04:44 PM
  #32
97Contour's Avatar
Originally Posted by thexlo8ers
Those fuel pressure readings are within spec. Key Off, the pressure will drop, and then should hold at about 25 psi. There is a check valve on the fuel pump that could be leaking. However, I don't think this would cause a rough idle in gear.
The IAC motor looks like this:
http://images.wrenchead.com/smartpag...S/217-1776.jpg
Does that 2.0 liter engine have Varriable Cam Timing, VCT? If it does there will be a connector, front of engine, about the middle of the valve covers, possibly with a rubber boot over it.
Here is a pic of VCT solenoid location:
http://t1.gstatic.com/images?q=tbn:A...h3J_o1ptjIJIyH
If it does, disconnect that connector, and see how will the engine idles in gear.
Also, have you ever disconnected the MAF sensor, and see how will the engine idles.
doesnt look like it has any connector on the valve covers, has a rubber line that runs from back cover to bottom of air filter box and that has some cracks but that appears to be a breather or something its about 1/2 inch to 3/4 rubber line so dont thinks its vacuum. Disconnected the maf, hard to tell if it got better..maybe but was still there especially if ac was on. Did notice that with the maf plugged in,seemed the idle dropped lower but not much
Old Sep 15, 2012 | 10:52 PM
  #33
thexlo8ers's Avatar
Ok, not an VCT engine. MAF sensor disconnect didn't resolve the problem.
That hose you discribed is the PCV breather.
IAC motor may be seen, and removed by lifting the vehicle, and looking up between the firewall, and the engine, under the throttle body. If not, remove parts around the throttle body to gain access to the IAC. It's on the bottom of the throttle body, almost completely underneath the intake plenum. Firewall side of engine.
Old Sep 15, 2012 | 11:35 PM
  #34
97Contour's Avatar
what is the sensor just past the maf on the bottom of the air tube?
Old Sep 16, 2012 | 12:17 AM
  #35
thexlo8ers's Avatar
Past the MAF, bottom of the throttle body. Remove the air tube to gain access from the top. Lean over the driver's side fender, and practically lay on the engine to see the dang thing. It's a pita to unbolt. The EGR valve is probably in the way too since the car is not a VCT engine. Perhaps you'll want to remove that too since you're in there, and it needs service anyway. I know, I know...ugh!
(Note: IAC is not a sensor. It's an output device controled by the PCM.)
Question: What is the idle rpm's when the car is in Park?
Old Sep 16, 2012 | 08:27 AM
  #36
bandit1948's Avatar
you don,t suppose you have a lifter sticking, do you ? you might not notice it at fast idle like on the highway, just at idle ! if it is a sticking lifter then the valves would not open and close right !
Old Sep 16, 2012 | 08:54 AM
  #37
97Contour's Avatar
no rpm gauge so i cant tell,i was actually refering to a sensor on the bottom of the air tube about 6 inchs past the maf sensor.
Bandit1948- i can be going 2mph as long as i have throttle on its smooth
Old Sep 16, 2012 | 10:58 AM
  #38
thexlo8ers's Avatar
Oh, my mistake, I miss read your question.
That would be an air temp. sensor. If that sensor was at fault you'd probably have other driveability and performance problems.
A smooth quality idle in Drive, regardless of loads put on the engine, like the AC, and power steering articulation, high beams, etc... is dependent on a properly functioning IAC motor.
Old Sep 16, 2012 | 11:26 AM
  #39
97Contour's Avatar
ok,I see where it is,is it easier to get it from the bottom? Can I just clean it?
Also, typical symptoms ive dealt with iac on previous cars where always high idle from sticking so how would it cause a rough idle? Is there a way to raise teh idle on these car? Sure theres no idle screw but some other way?
Old Sep 16, 2012 | 12:36 PM
  #40
thexlo8ers's Avatar
Yes, it may be easier to get to from the bottom. Make an attempt, and see. Or, you may choose to go from the top. It really depends on the mechanic, space, and available tools.
If the IAC motor is dirty a through cleaning with plastic safe throttle body cleaner may do the trick. Make sure you also clean the throttle body ports, where the IAC attaches. You should see cleaner come out of the throttle body behind the throttle plate when you spray the cleaner into one of the IAC ports.
Check all hoses going into the throttle body, and PCV hoses, valve, and breather hose, and breather element. These componets should be clean and/or replaced too.
