Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
Rough Idle
Old Sep 16, 2012 | 12:59 PM
  #41
thexlo8ers's Avatar
Originally Posted by 97Contour
ok,I see where it is,is it easier to get it from the bottom? Can I just clean it?
Also, typical symptoms ive dealt with iac on previous cars where always high idle from sticking so how would it cause a rough idle? Is there a way to raise teh idle on these car? Sure theres no idle screw but some other way?
A stuck open IAC will cause a high idle. A clogged IAC system can cause a rough idle since the amount of air needed is blocked for smooth operation, or the valve does not seat properly.
Some Fords do have a factory set idle stop screw located on the throttle body or accelerator cable assembly. However, tampering with such a screw may cause false TPS signals to the PCM.
Old Sep 16, 2012 | 03:16 PM
  #42
97Contour's Avatar
ok,ill just try to clean the iac first than. It does get worse after the car warms up also
Old Sep 17, 2012 | 08:20 AM
  #43
bandit1948's Avatar
maybe a lifter is sticking or an injector is ganging up !
Old Sep 17, 2012 | 07:08 PM
  #44
97Contour's Avatar
bandit1948
i ran some seafoam through the gas,didnt help. Also if it was a lifter it would be doing it at idle in gear also wouldnt it?
Old Sep 19, 2012 | 08:26 PM
  #45
97Contour's Avatar
cleanedthe iac(bestthat i could),still didnt fix, maybe it needs a new one?
goatsauce
Apr 15, 2013 08:32 PM
93redxlt
Mar 18, 2010 04:44 PM
Olpapa
May 18, 2008 03:22 PM
wheelerlt
Nov 15, 2005 09:40 PM
gearyoil
Nov 1, 2005 07:02 PM
