Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
Struggling to do a timing belt on 2000 ford contour 2.0l 4cyl
Old 09-11-2018, 08:02 PM
Jamesleandre's Avatar
Default Struggling to do a timing belt on 2000 ford contour 2.0l 4cyl
How is everyone doing today ? I have a 2000 Ford Contour 2.0L 4CYL.
The timing belt is old, so I decided to change it.
I had put the cylinder number one at TDC , with the screw driver in cylinder number one to
see when the piston is at TDC, and the two exhaust lobes pointing at the exhaust, and the intake lobes pointing at the
intake. I had put the camshaft locking tool on the cams to lock them at TDC. The Torx screw from the exhaust cam
had loosen, but the screw from the intake cam wouldn't loosen us. I sprayed it down with PB blaster and tried to
loosed it up with the impact wrench. I couldn't get is loose. I installed the belt on the Ford Contour, and rotated the engine
twice to see if the engine stayed at TDC. I put the engine components back together and tried to start the car. The engine didn't start.
The next day I was off work, I put the engine back at TDC, put the camshaft locking tool on the cams.
I loosened up the intake cam using an Impact tool set. With both cams loose I set both cams at TDC then tighten them down.
I rotated the engine twice, and rechecked the timing. When I put the engine components back together,and tried to restart the
engine. The engine still would start. Your advice is appreciated to solve this problem
mmurphy
11-15-2010 08:03 PM
Qaiphyx
04-04-2008 11:59 AM
jallenfarm
01-25-2008 12:58 AM
plolo
08-29-2007 12:42 AM
chris55692000
08-06-2006 05:38 PM
Quick Reply: Struggling to do a timing belt on 2000 ford contour 2.0l 4cyl
