Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
trans replacement
Old Jul 22, 2012 | 08:20 PM
wags70ss's Avatar
Default trans replacement
I have a 99 contour with the 2.0 engine & I need a transmission for it. Does anyone know which transmission will work in it?
Old Jul 23, 2012 | 03:54 PM
bluewind's Avatar
These transmissions carry the code: CD4E
Old Jul 24, 2012 | 08:49 AM
wags70ss's Avatar
Ok thanks. What years & models will fit in a 99 contour?
Old Jul 24, 2012 | 03:33 PM
bluewind's Avatar
I believe (which means I don't know for sure) they all have the same CD4E automatic transmission from '95 through '00. To be sure you could call a junk yard and talk to them.
If I had to replace the tranny I would stay with a donor car that has the same 8th position VIN code. "L" is for 2.5L V6 and "3" stands for the 2L I4 engine. There may also be some Z code engines which are 2L I4s as well. It is possible that they have different end gearing. But again I don't know for sure.
Find a very low mileage transmission and have it bench tested by a tranny shop before you plunge down all that money for a swap.
These transmissions are very sensitive to lack of maintenance and overheating.
In fact, I would get an estimate for the work because it takes countless hours in these cars. You may be better off buying another running car and parting your current one out.
ronman351w
Feb 12, 2015 03:23 PM
conanalois
Aug 31, 2013 06:16 AM
Ranger
Jul 23, 2012 08:29 PM
NOS/MAN
Apr 20, 2004 01:42 PM
mrwhipper
Apr 18, 2004 09:33 AM
