Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
Transmission or Not?
Old Nov 26, 2010 | 04:15 PM
TonyReynol's Avatar
Question Transmission or Not?
I have a '96 Ford Contour. 175K miles. I'm have an odd problem with the car and it's shifting of gears. Automatic Transmission. When I first start the car, it runs and shifts through the gears just fine. After the car warms up, a mile or two, or if I just let it warm up in the garage for 5-10 minutes, it doesn't want to shift gears - like it's stuck in neutral.
I drove it around the block today (2 miles). Worked great until about the 1/2 way point, then it began acting up and not engaging any gear. If you stop the car, turn it off, let it sit for a few minutes, start the car, shift the car into 1st gear, it'll go for a short distance and then, again no gears. I was listening and experimenting and it seems to shift from 1st to 2nd, but that's it before it just looses all "gearing" and coasts to a stop or I manually stop and turn off the engine.
Is this the transmission or am I missing something? Tranny fluid is good.
Old Nov 27, 2010 | 04:42 PM
When was the last time the trans filter was serviced?
Old Nov 28, 2010 | 03:57 PM
TonyReynol's Avatar
Thumbs up Transmission Filter...
I've never heard of a transmission filter... until now. Obviously I'm not a "car dude." 1st item I'll check.
petehack
Nov 10, 2014 05:20 PM
ston57
Oct 6, 2013 03:15 PM
Paul McIntyre
Oct 16, 2012 03:54 PM
