'04 Crown Victoria HVAC Problems-Need Help!!!
Old Jul 13, 2017 | 03:38 AM
Iamgrim3's Avatar
Default '04 Crown Victoria HVAC Problems-Need Help!!!
So I'm driving down the freeway a/c blowing out the vent (like normal) until it hit about 55 mph. Then it begins blowing out the defrost right....well then I begin to slow down , and it comes out the vent again. Now I've noticed it does this Everytime I accelerate for an extended period it switches to the defrost output and when my speed goes back down it goes back to normal.
Im thinking it may be a vacuum line ...anyone had this happen????
Old Jul 1, 2018 | 05:11 PM
raybyrd's Avatar
Default Cv hvac
I have the same problem, got no idea.
any luck on your side?
Old Jul 1, 2018 | 07:52 PM
I believe you are on the right track suspecting a vacuum problem.
The systems are designed such that if normal controls fail, for whatever reason, the system defaults to defrost in case the problem appeared in the dead of winter.
A thorough check of all the vacuum lines and components should be performed including the vacuum reservoir itself.
Old Oct 3, 2018 | 08:45 PM
Gil Coles's Avatar
I had the same problem. I put new 007 o rings on all 4 solenoids on back of temp control unit. $5 dollar fix.
Iamgrim3
Jul 13, 2017 09:27 AM
cypressdelight
Jun 18, 2015 11:14 PM
MGood777
Jul 23, 2013 08:11 PM
jacklane21
Jul 11, 2012 10:29 AM
dgoodall
Jun 3, 2010 09:58 AM
