04 Crown Victoria Interceptor only starts when warm weather
My 04 Crown Victoria won't start. Mechanic changed the fuel pump. It still doesn't start unless it's 70 degrees or hotter outside. I swapped the fuel pump driver module. It didn't solve the issue. Do you guys have any ideas?
Last edited by #1fordForum; May 24, 2024 at 02:52 PM. Reason: Sorry, first time posting a question and it's a duplicate.
You can click "edit", then click "delete" right above the edit button to delete your other duplicated message.
You said your car only starts when cold and no start when warm. Do you mean "no crank no start" or "crank but no start"?
Your check engine light functioning or not? Turn your key to ON position, can you see the light? Once you start it the light goes away, then your CEL bulb check is working. Do you have any CEL?
What's the battery voltage reading when cold, and when warm?
#1fordForum
Apr 25, 2024 02:58 PM
