1989 Crown Victoria LX.... Idle problem
Old Oct 27, 2023 | 05:00 AM
Joe Reeves's Avatar
Default 1989 Crown Victoria LX.... Idle problem
1989 Crown Victoria LX, 302 Eng, loaded.
The idle rpm dropped to a point whereas the engine would not stay running...... Vacuum leak/break? If so, the most likely area?
As it stands... necessary to keep gas pedal depressed with right foot, using left foot on brake pedal to control the speed of the vehicle... spooky!
Old Oct 27, 2023 | 07:28 AM
Sounds like you are on the money with a vac leak.
Have you tried to spray a little brakekleen or carb & choke cleaner around the vacuum lines and intake manifold.
Don't forget to check the vacuum reservoir ..
Radu Georgescu
Jul 26, 2016 07:31 PM
leeval2011
Mar 21, 2011 08:32 AM
leeval2011
Mar 18, 2011 09:05 PM
wantz_a_shelby66
Apr 28, 2010 07:29 AM
fordstang
Feb 20, 2008 09:18 PM
