1991 Ford Crown Victoria P72 5.8L 351 carburetor Rebuild or new aftermarket help
Old Apr 19, 2024 | 11:08 PM
93p71's Avatar
Default 1991 Ford Crown Victoria P72 5.8L 351 carburetor Rebuild or new aftermarket help
Is is better to rebuild the OEM carb or upgrade to aftermarket? Pros and cons of both options?
If so, any recommendations for aftermarket intake manifold and carburetor for this 5.8L: 351? Will original carb sensors and electronic harnesses be compatible?
Old Apr 20, 2024 | 01:29 PM
Don't know the reason you feel the carb has a problem. 2 barrel or 4 barrel carb ?
Could you enlighten us?
Old Apr 25, 2024 | 10:10 AM
93p71's Avatar
Very hard to start on cold starts. Tiny amount of starter fluid direct into carb helps to start. No smoke from exhaust when started. Once started it idles pretty good however it does occasionally stall while driving. Car only has 41k but has been garaged for many years. Recently replaced fuel tank as there was rust deposits in old gas so now on the carb. Not sure if rebuilding OEM carb is best solution or open to suggestions on which 2 barrel or 4 barrel intake and card setup to replace with.
1972 351 Boss +30 OB
Jan 15, 2019 10:57 PM
dalesgarage_2250
Sep 24, 2010 07:57 PM
dalesgarage_2250
Sep 24, 2010 07:55 PM
ryanxxx
Aug 29, 2008 12:11 PM
sureshot
Aug 21, 2007 11:08 PM
