A/C issue
Old Apr 20, 2019 | 11:05 AM
Mack Ward's Avatar
Default A/C issue
2004 Ford Crown Victoria, hot weather stop and go traffic a/c will not blow cool air, get back on the highway and will work..
Does not run hot. Has freon, compressor works, radiator clean.
Whats the issue? Compressor Ideal Switch???
Old Apr 22, 2019 | 04:49 AM
raski's Avatar
Can be a vacuum issue with a blend door.
Old Apr 29, 2019 | 09:46 AM
Use Common Sense's Avatar
Could also be borderline low on refrigerant charge. Have you verified that the cooling fans are operating properly? They may not be coming on in the "HIGH" speed when you need to move more air in the stop and go traffic which is when you need the air flow.
Chifilli
Mar 24, 2015 08:54 AM
RH2OMAN
Nov 23, 2011 03:57 AM
fblevins1
Apr 30, 2009 07:56 PM
mattman
Jul 5, 2007 09:37 PM
gtam03@aol.com
Nov 20, 2006 12:24 PM
