Crown Victoria problems
Old Oct 14, 2017 | 09:08 PM
Onepoorguy's Avatar
Default Crown Victoria problems
I have a 2002 Ford Crown Victoria. Wiring on the starter was completely corroded away which is why it wouldn’t start so I replaced the starter, has a brand new battery. Drove about 20-25 miles highway and some stop and go, ran great! Turned on a side street and the car shut off but still had plenty of power and still does. Cranks like hell but won’t turn over. Found that a 20 amp fuse under the dash for the fuel pump has blown. Any red flags for that?
Old Oct 14, 2017 | 11:22 PM
Welcome to the site..
Looking st the CJB, only 20 amp fuses show to be Power Points (cig lighter-flasher relays), Driver Door Module, ABS Module. Battery Box has a 20 for the fuel pump relay.
What position is the fuse that blew in within the CJB?
Old Oct 15, 2017 | 06:18 PM
Onepoorguy's Avatar
Thanks for the welcome! The position the fuse that blew is in slot #5 and it’s the fuse box under the drivers dash. Stoped at the auto parts store and picked up a pack of the same 20A fuses, replaced it and runs like a champ. Go figure. Even drove around the neighborhood hot rodding it if you will trying to see if it would blow again but didn’t. I know the fuel pump doesn’t sound the same like it used to a while back, good and loud if you liston well. It does have 162,000 on it and I bet it’s the original fuel pump just like the starter that corroded to dust lol. Dreading replacing the fuel pump which I will have to do myself
BUYmy94
Sep 10, 2019 07:33 PM
Iamgrim3
Oct 3, 2018 08:45 PM
Iamgrim3
Jul 13, 2017 09:27 AM
llogan_jones
Jun 18, 2013 11:47 PM
johnvic
Aug 4, 2005 04:17 PM
