Leaking Water Pump HELP. :/
Water pump leaking. Bought new water pump. I know about reverse thread-supposed to loosen the same way fan turns-but with a water pump pulley holder tool & pipe wrench on fan clutch nut, the nut won’t budge..
Also, with little room to moving around due to HUGE fan shroud that cannot come off unless you remove the fan clutch with the shroud, it makes this job so much more stressful lol. Does anybody happen to have any suggestions/advice? Thanks guys.
Last edited by TooTall92; Sep 30, 2017 at 08:35 PM. Reason: Just need to change the title.
This must be on a 7.3 correct?
There is a set of special large open end wrenches just made for handling these fasteners. Possibly you might be able to rent then from an auto supply store or if not practical, I have managed to loosen them with rapping on the nut with a long heavy screwdriver. Remember that it is left hand thread and you have to be trying to go in the direction of what would appear to be tightening a normal fastener. No sense worrying about damaging the water pump since it is getting replaced anyway.
