Technical ignition/fuel help
Old Jul 29, 2020 | 03:36 PM
Sp0rttraxx's Avatar
Default Technical ignition/fuel help
Hello all, I’m working on a large project and fear I may have bitten off more than I can chew. I’m taking a 2011 crown Vic P71, removing the body, and setting a 62 F100 unibody on the chassis. As of now I have the entire body off of the crown Vic and things were going ok. I thinned out the body harness to just essential run/drive components. I hooked the harness back up to the rolling chassis to confirm it still runs and I have no ignition or fuel. The questions I have are as follows
would it be possible to just get a plug and play Holley system? I know it’s been done but I have no idea where to start. All I know is that I would have to swap to a mechanical throttle body
From what I’ve seen the fuel system is returnless? And just regulates the fuel pressure by changing voltage to the pump. How would this work with changing to a fuel cell?
Any input is greatly appreciated
Rotarran9116
Aug 15, 2020 09:03 AM
Verastyles
Apr 23, 2018 09:09 AM
edwardk
Sep 27, 2012 05:16 PM
cbfan5
Sep 3, 2009 07:38 PM
96cvpi
Mar 28, 2006 01:45 PM
