1980 motor home e350
Old Jun 1, 2020 | 11:22 AM
fastonraceday's Avatar
Default 1980 motor home e350
it has a 460 in it and i cannot find the fuel pump. there was one in the back added later but i cannot find the original locations. none of the fuel pumps work.
Old Jun 5, 2020 | 04:59 AM
raski's Avatar
Being a 1980 model and carbed, it likely has a mechanical fuel pump, it will be bolted on the block, probably in the front, driven off the cam. But being an RV, I could be wrong.
Old Jun 5, 2020 | 10:03 AM
tha's what i thouht, but thetre are two gas tanks in the back, two electric fuel pumps, both wore out, and a block off plate up front. what kind of pressure and volume are needed in a fuel pump?
Old Jun 5, 2020 | 02:15 PM
If I recall correctly a typical chassis mounted electric fuel pump for carbureted engines only needed to provide about 5-6lbs of fuel pressure and around a qt/min.
Any more than that would overcome the ability of the float to limit the amount of fuel in the fuel bowl. If that were to happen the result would be an over rich condition that was not able to be controlled and the result was flooding..
I seem to remember there was a problem with Ford 477 CID engines that performed better with "Carter " fuel pumps.
harrisg
Jun 8, 2012 09:26 PM
markcass123
Apr 19, 2012 08:48 PM
82BroughamRV
Apr 20, 2011 07:18 PM
themaker
Oct 2, 2009 09:59 PM
83ford
May 5, 2004 08:17 PM
