1989 f350 petrol running extra rich
Old Jul 11, 2019 | 08:52 PM
  #21
rumbap's Avatar
Many thanks
8th and 10th on vin is G K.
phillip
Old Jul 27, 2019 | 09:18 PM
  #22
rumbap's Avatar
thought I had found the "TEST" outlet but turned out to be the seat buzzer.
Old Jul 23, 2021 | 10:00 PM
  #23
Shaggydfordguy's Avatar
Default My fuel pressure regulator was bad. Replaced it..my 1995 f350 7.5 460 came to life! .
Sorry..first time on here..wrote too much up top..I need help! My 1995 f350 had no power at all. Fired right up and idled ok..sounded sluggish. I replaced plugs wires rotor distributer and coil..no change. Then..I changed the fuel pressure regulator and boom...amazing truck..I mean wow! What a hoss....for two days. Then I felt it change. Got another day of decent performance. And now it's leaking and even spraying fuel from the regulator again..what would cause this? Please help!
Old Jul 24, 2021 | 02:17 PM
  #24
When you say spraying from the regulator, where ?
The regulator is usually held in place with 2 or 3 allen head screws. Usually "O" rings under it's mtg..
If the regulator is a cheapy from a china aftermarket supplier , questionable quality.
The fuel pump in the tank will supply sufficient pressure and the regulator is what is controlling just how much goes to the injectors and the rest goes back through a return line to the tank.
Does your vehicle by any chance have dual fuel tanks?
n.shift
May 17, 2016 06:01 PM
Firemen628
Mar 16, 2011 08:43 AM
Ranger999
Mar 26, 2010 11:02 PM
bigdaddyb74
Oct 23, 2008 05:50 AM
fastvee
Jan 10, 2008 07:10 AM
