1991 e150 4.9 no start
Old Mar 11, 2022 | 09:59 AM
DLESTER56's Avatar
Default 1991 e150 4.9 no start
My e150 slow crank and will not start. Battery has full charge and starter is good. I pulled the starter off and tested it.
Any helpful tips.
Old Mar 11, 2022 | 11:57 AM
If you did voltage drop tests on the battery cables and they passed with the maximum drop of 0.05 volts , good , otherwise you may need to determine where the drop is taking place and correct it Let us know how you make out, thanks.
Don't forget you need to test the circuitry under load , that means while attempting to start the engine.
Old Mar 11, 2022 | 12:02 PM
DLESTER56's Avatar
Thanks. Also do you know where the engine ground strap or wire is located.
Old Mar 11, 2022 | 02:53 PM
raski's Avatar
The 4.9's engine ground is located at the right front area of the engine. It is difficult to see and access. On my 4.9, I made a new negative cable and attached it to a mounting bolt on the starter. If your battery cables are original, may not be a bad idea to replace them.The battery needs to be tested under load.I would have it and the starter tested at your parts store.
Old Mar 11, 2022 | 03:20 PM
DLESTER56's Avatar
Thank You
sneakybassturd
Dec 28, 2023 03:59 PM
mikey p
Jan 6, 2015 09:45 AM
deathbymonkey
Nov 23, 2011 01:36 PM
PTT
Jan 13, 2008 01:57 AM
pilotlars
Aug 10, 2006 09:04 PM
