1992 E150 showing codes AFTER tune up
Old Jun 25, 2020 | 01:33 PM
MelKJO's Avatar
Default 1992 E150 showing codes AFTER tune up
My van is throwing codes after I did a tune up. I replaced the spark plugs, distributer cap and rotor. I also did a flush of the radiator. After 2 minutes of running the check engine light came on. I plugged in the OBDI and the codes that came back were 311, 411, and 538. Anyone have any Ideas? The book says its not regulating the RPMs yet drives better than before.
Old Jun 25, 2020 | 06:30 PM
In the process of flushing the radiator , did you manage to get some parts of the engine and wiring wet?
If so, most of the time with a little time and warm engine temp the codes just might not come back after being cleared.
Old Jun 25, 2020 | 06:36 PM
In the process of flushing the radiator, did you manage to get parts of the engine and wiring wet?
If so, after the engine has warmed up a bit, clear the codes and go have a cup of coffee. This could be one of those times where patience pays off and the water in the wrong place may dry and the codes go too.
Old Jun 26, 2020 | 08:30 AM
raski's Avatar
Vacuum line leaking might cause all three of your codes. Did you disconnect anything?If your 92 van has the 4.9, you could have bumped and broke a plastic vacuum line on your solenoids which are mounted just above your # 5 and 6 spark plugs.
Old Jun 26, 2020 | 11:52 AM
MelKJO's Avatar
Yes, some things got wet. I have driven the van for 200 miles or more yet the check engine light is still coming on.
Old Jun 27, 2020 | 10:01 AM
Is the light coming on with the same codes?
Old Jun 27, 2020 | 11:13 AM
MelKJO's Avatar
Hanky,
Yes. It comes on anywhere from 1 to 4 minutes after driving. If the AC is on the check engine light comes on sooner. If it helps it is a 5.0 engine with a Tradewinds package in the back.
Old Jun 28, 2020 | 05:36 AM
What code(s) are you getting?
donnie beasley
Apr 11, 2020 11:28 AM
BL00DPIG
Sep 26, 2019 04:27 PM
wanness
Feb 19, 2017 05:15 AM
jlawson435
Oct 12, 2015 01:31 PM
curtie94
Oct 6, 2011 07:38 PM
