1996 E350 5.8L 351 misfire
Old Jun 18, 2025 | 12:12 PM
  #51
Picture the following,
Garbage in the filter held there by the pressure.
When the key is turned off and that pressure drops down, that garbage in the filter also goes back toward the tank. The key is turned on, the pump is primed, and that garbage in the line goes back to restrict the fuel filter , again.
Have seen that more than once.
Fuel filters should be changed in the spring and in the fall. The cost is small, but the benefit is large. !
If there is water contamination, filter will need to be changed more often.
The problems it causes, if restricted , are big compared to the cost of a filter.
Old Jun 20, 2025 | 10:03 PM
  #52
MacGyverMU's Avatar
No otherwise contamination. Filter replaced. What are your thoughts on the TFI module being the problem? Pressure showing 35 now steady. Symptoms getting worse now happening even cold and no load. Just a quick throttle at times would either rev perfect or occasionally hesitate before power.
Old Jun 21, 2025 | 08:50 AM
  #53
What is needed here is a scan tool that shows the operating parameters, DATA STREAM info. With that info we would have a better picture of just what is happening.
Guessing can get expensive and disappointing.
Intermittent problems are a tech's worst nightmare , but the data stream info shows exactly what is happening and when.
Old Jun 29, 2025 | 07:27 PM
  #54
MacGyverMU's Avatar
Sometimes, after hot, in gear, give it gas with load, it will hesitate or feel like a misfire sometimes then provide full power. At times, it may even die.
File Type: mov
Old Jul 12, 2025 | 09:43 AM
  #55
MacGyverMU's Avatar
Default Partially solved
I decided to replace the dpfe sensor. Issue is now almost all the way gone yet i now get a pending po402. The egr seems to be working well yet don't know why it seems to open too often or much at low rpm. Still troubleshooting.
Old Jul 12, 2025 | 08:16 PM
  #56
If you took the hose to the EGR valve off and plugged it, Does the problem go away?
If it does, problem is in vacuum control to EGR valve.
If it does not, EGR valve may be full of carbon and may need to be removed and cleaned so it can fully seat and provide better idle and also performance.
Old Jul 13, 2025 | 07:01 PM
  #57
MacGyverMU's Avatar
I took the valve off and notice the diaphragm is leaking a bit. I notice the valve opens and closes all the way, just won't stay open with pumping vacuum. Ordered new one to arrive in another week.
Old Jul 13, 2025 | 08:00 PM
  #58
If the EGR valve is open all the way ,it will at idle stall the engine. Diaphragm should not leak though.
Might be a good idea to read up on EGR valve function.and operation.
Old Jul 26, 2025 | 01:34 AM
  #59
MacGyverMU's Avatar
After replacing egr, I now get po401. So I'm now thinking also the control solenoid must be bad as well. All hesitation seems gone so far, just a full check engine light. Strange how engine was running bad without any lights at first.
I understand the function of the egr valve, what more did you want me to read on it?
Old Jul 26, 2025 | 05:47 AM
  #60
Now that you have some idea of what it does, the next thing to know is when and how it is controlled to do what it is supposed to do.
After that the mystery of "The EGR Valve " will no longer be a mystery and you will know more than a lot of shops that replace a lot of good parts, lol.
