2005 E150 Power Windows
Old Apr 6, 2019 | 02:46 PM
Kkcamp's Avatar
Default 2005 E150 Power Windows
Hi y’all,
I just purchased a 2005 Ford E150 Van. There’s a problem with the power windows on the drivers side.
The driver side switch does not work for either the driver window or the passenger window. On the passenger door the switch and window work fine.
I’ve ruled out problems with the fuse, and the switches and the motor. I’m at a loss. When I try the switches there is so sound, or movement of any kind.
Any thoughts?
Old Apr 6, 2019 | 07:00 PM
That question always comes up, how was it determined the switches and motor were OK ?
Did you check the wires in the diver's side door hinge area for a possible broken wire?
Old May 10, 2019 | 06:32 PM
Kkcamp's Avatar
I removed the switches and motor from the drivers side door and tested them on the passenger door (which was always working fine)
I did end up checking the wires in the door hinge and found a broken wire. Replaced it and now the power windows are all working!
Thanks for the help
neljer00
Oct 1, 2016 11:45 AM
obieone1
Sep 16, 2013 04:22 PM
cdpromusic
Mar 7, 2012 10:00 PM
JesusKnievel
Aug 8, 2008 12:12 AM
Ughx
Jan 6, 2008 09:11 AM
