Power windows acting up
Old Aug 4, 2013 | 04:50 PM
obieone1's Avatar
Default Power windows acting up
Problems with the power windows on my 1996 F-150 Extended Cab XLT. Sometimes neither window operates from the driver's door switches, and at other tiimes both windows work. Sometimes only one or the other work from the driver's side. And sometimes the passenger's window might or might not work from the passenger side switch. At first I suspected a ground problem, now I'm not sure. I have noticed that when I operate the switches the charging guage needle on the dash deflects, which indicates the switches are causing a power draw, and I can hear a distinct clicking sound. I have sprayed the switch assemblies with CRC Electrical Contact Cleaner, but it hasn't helped. Sure would appreciate any suggestions if someone else has encountered these problems. TIA.
Last edited by obieone1; Aug 18, 2013 at 02:54 PM. Reason: To provide additional diagnostic info.
Old Sep 11, 2013 | 09:08 PM
switch doctor's Avatar
I would check the wiring at the master switch, if it checks out all good then more and likely the window switch.
Old Sep 14, 2013 | 11:38 AM
Rusty Baker's Avatar
Originally Posted by CasseySwartout
it is suggesting the trouble in making and you must not go light with it as you have seen that there is no dirt or particles causing so to happen .. now is the time to rush to the near automobile repair shop
What?.....
Old Sep 14, 2013 | 11:49 AM
It's too complicated for me to understand.
Old Sep 15, 2013 | 09:13 AM
obieone1's Avatar
Don't try reading between the lines. You've got to read between the words to understand it.
Old Sep 15, 2013 | 09:21 AM
Do you think you could help us out and decipher this "coded" message ?
Old Sep 16, 2013 | 04:22 PM
obieone1's Avatar
I'm sure Cassey is trying to be helpful. Decoded, his message means "Quit trying to solve this problem yourself. Go to a professional repair shop." I
interpret this to mean that Cassey belongs to a union, and wants me to go to a union shop for the repairs.
Alex
Dec 4, 2007 06:40 PM
94 loneranger
May 4, 2007 11:40 PM
F250LOVER
May 23, 2006 12:32 PM
MSTHTD1
Feb 24, 2006 07:34 PM
anthony
Sep 11, 2005 04:02 AM
