2010 E-150 (4.6) - Confirm uses exhaust studs?
Old Dec 4, 2025 | 02:29 PM
hendr1x's Avatar
Question 2010 E-150 (4.6) - Confirm uses exhaust studs?
Hello everyone, Apparently my cat got destroyed and I need to replace it. I'm trying to take it off and the bolt on the flange between the exhaust manifold and the car completely rounded off. Can someone confirm that is a stud that I can destroy/replace? I just want to be 100%. Thanks.
Old Dec 4, 2025 | 06:05 PM
Those studs can break and then you have a bigger problem. Then they will need to be drilled out, not the kind of job you have the tools to handle. NO ROOM !
Suggest you consider a shop that can use heat to remove them before breaking them.
That is not a job you want to become involved in lying on your back.
A muffler shop has a lift and is equipped to use a torch if necessary.AND they will have the replacement studs and usually brass nuts.
Old Dec 5, 2025 | 06:38 AM
dpboone's Avatar
I agree! A muffler shop with lift can do this job quickly. You could spend days trying to do this yourself !!!
Trikerkent
Dec 6, 2023 01:05 PM
Bo Ekenbro
Jun 21, 2018 10:44 AM
thebeebs
Jul 15, 2013 11:09 AM
rogerb
Nov 15, 2011 09:05 PM
Keeper1200
Jan 14, 2008 06:05 PM
