1992 ford econoline exhaust with cat
Old Dec 4, 2023 | 12:08 PM
Trikerkent's Avatar
Default 1992 ford econoline exhaust with cat
Good evening folks does anyone not if i can alter exhaust after the cat.. i.e i want to haveside exit exhaust 1 each side and was wondering if this is going to affect proformence and reliability the engine 5litre v8 ... any advice would be appreciated as not really experienced with cat exhaust systems many thanks in advance ....
Old Dec 4, 2023 | 02:32 PM
Most likely not, but make sure to provide shielding for heat and fuel tank.
Old Dec 6, 2023 | 06:13 AM
Trikerkent's Avatar
Default Thanks for reply
Thanks hanky for reply did yoj mean it shouldnt be a problem?
Old Dec 6, 2023 | 09:47 AM
It will not affect performance.
The idea is to not direct any heat from the exhaust pipe , which gets pretty hot, near the fuel tank.
Some vehicles have fuel tanks midship and some in rear also.
When manufactured, the manufacturer usually provides some heat shielding to prevent the heat from the hot pipe getting too close to the gasoline.
That could be a problem.
Old Dec 6, 2023 | 01:05 PM
Trikerkent's Avatar
Default Thanks
Thanks hanky yes i will bear that in mind with regards the heat ... and thanks again
green94f150
Mar 27, 2024 07:17 PM
shilowar
Jan 11, 2019 04:02 PM
Old4xford
Feb 14, 2012 12:48 PM
blackharley
Oct 21, 2008 09:31 PM
fordman87
Oct 7, 2005 07:40 PM
