2012 E-250 Flasher Relay Location
Old May 26, 2020 | 05:55 PM
hurricanejohn's Avatar
Default 2012 E-250 Flasher Relay Location
I have a 2012 e-250 and for the life of me I can't find the flasher relay. does anyone know where it is? I've taken the entire dash apart except for the top and can't find it anywhere. Ford tells me that it's to the left of the radio location. i can't get my hand in there will I have to take the dash board off? I'm almost thinking it would be easier to put resistors on my LED signal lights.
Thanks for any help
Old May 27, 2020 | 12:01 AM
Turn signal/hazard lamps are pulsed by voltage from the SJB..
Old May 27, 2020 | 12:36 PM
Question need clarification
I'm unsure what you mean is there a flasher unit somewhere?
Old May 27, 2020 | 07:36 PM
The smart junction box pulses the turn/hazard voltage. No flasher unit.
Old May 27, 2020 | 08:07 PM
Do you know of any way to make my LED lights from flashing rapidly when i use the turn signals
Old May 28, 2020 | 10:15 AM
Being the wattage isn’t consistent or matched between incandescent and LED the SJB will pulse/flash the LED faster as it would with a bulb out with standard units. I’d assume you’d need to match the resistance to get a standard flash rate.
Drag Racer's Daughter
May 15, 2012 06:14 PM
troyhay
Nov 4, 2010 04:47 AM
firesheriff
Oct 31, 2007 02:19 PM
barnall
Sep 14, 2006 11:28 PM
babybuck
Mar 22, 2006 12:48 AM
