2013 Econoline E-350 Turn Signal
Old Mar 3, 2022 | 03:33 PM
barcuss's Avatar
Default 2013 Econoline E-350 Turn Signal
Driver side rear turn signal is not working, I have replaced the bulb and checked fuses. What else could I check to get this fixed? All other signals and break lights are working perfectly.
Old Mar 3, 2022 | 05:03 PM
Sometimes a simple light problem can get a little complicated especially if a Body control Module is involved..
Aside from that what might help would be to start working either from the signal light switch out to the lamp in the rear or working back from the lamp with the lamp requested on and checking for the break possibly in the wire from the switch to the lamp with either a test light or voltmeter.
Old Mar 3, 2022 | 06:50 PM
Rusty Baker's Avatar
Could be as simple as rust in the socket.
Old Mar 4, 2022 | 03:18 AM
raski's Avatar
Do you have brake lights? I echo the thought of a bad socket. I had the same issue recently up front with turn signal and park light inoperative.
Ant
Aug 25, 2021 09:43 AM
grandmarquisNM
Jul 21, 2012 10:30 AM
hmcgary
May 1, 2008 01:30 PM
cat
Mar 11, 2006 10:57 PM
harlem
Jan 16, 2006 03:35 AM
