2002 F250 Hazards/Turn Signals
Old Aug 22, 2021 | 08:36 PM
Ant's Avatar
Ant
Default 2002 F250 Hazards/Turn Signals
When putting on the hazards,they may flash a couple of times the stop. Then the other day the passenger side turn signal would flash a few times then stay on(the driverside turn signal works fine)the arrow stays on and the actual bulb does also. Where is the relay located?
thanks
Old Aug 23, 2021 | 06:17 AM
When the Rt side turn signal is selected and ,,,,,,,,,stays on,,,,,,are you sure both front and rear lights are on too?
Old Aug 23, 2021 | 07:28 AM
Ant's Avatar
Ant
Yeah,front and rear signal stay on.
Old Aug 23, 2021 | 07:59 AM
I believe there is an electronic flasher (5 terminals) inside the dash to the right of the steering column. Sometimes they are mounted with another relay or two..
If you remove the curved cover under the steering col (4 twist lock screws) you should be able to see the flasher . It is only about 1 in square , about 11/2 in long , black.
What you might consider would be to purchase a new flasher from an auto supply store, . Now you will know what you are looking for. Unplug the old one and plug in the replacement..
What is puzzling is the left side seems to work OK, and the right does not. . This situation does not necessarily condemn the flasher.
Those years and models had a problem with the windshield leaking and messing up the GEM (generic electronic module) that produced some crazy results that defied explanation. That module is located under the dash on the driver's side. Sometimes we were able to wash out the moisture with an electronic spray cleaner.. If you look under the dash on the driver's side above the parking brake assy and see a lot of rust , that could be the cause of why one side works and the other doesn't.
Old Aug 23, 2021 | 04:01 PM
Ant's Avatar
Ant
I'm going to take a look this weekend or when time is available.Thanks
Old Aug 24, 2021 | 08:28 PM
Ant's Avatar
Ant
I had some free time after work today,went and bought EP27 (flasher/signal relay). I went through where the ashtray would've been,two screws pulled the piece off. It was a tight fit for my arm but it's done and Working.
There's a spot right beside it,empty where another relay would go,what might that be?
Old Aug 25, 2021 | 07:14 AM
Some vehicles have the wiring harness built to accommodate addl features the purchaser may want. Just which feature that particular plug may be for is not known without checking a diagram. Not to worry nothing important is missing, just addl wiring for something the buyer did not want..
Old Aug 25, 2021 | 09:43 AM
Ant's Avatar
Ant
Oh man! Got in the truck this heading to work and noticed a clicking,like when the turn signals or flashers are on but they wasn't be used. I turned the truck off and still heard the clicking,I really didn't have time to look,cause of work. Any idea what THIS could be?
Bigdigger
Sep 9, 2019 04:00 PM
Cory Revert
Sep 24, 2018 07:56 PM
grandmarquisNM
Jul 21, 2012 10:30 AM
1bigfordlover2
Sep 17, 2010 04:42 AM
EGamble3
Feb 16, 2009 12:25 PM
